License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
PDF with AC 10
It is little bit too early to ask:
Can we work on PDF-file in AC10?
In the past time I had to do the followings:
First open the PDF with Adobe Illustrator, and than save as DWG, and than exprot to PM, and from PM save as DXF, and open this file with AC.
With AC10 can we work directly PDF as vector form?
If it is possible, than first trial with any CAD-programms, isnt it?
5 REPLIES 5
Djordje
No.
You can only place it.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje wrote:
No.
But if you edit it in Illustrator, Acrobat, etc. it will update in ArchiCAD.
Than it is not new. It was also possible with AC9, isnt it?
Ben Odonnell
Yes it's new,
It couldn't be done in ArchiCAD 9.
CHeers.
Ben
Ben O'Donnell
But anyway you can export PDF to DWG with Illustrator.
