Tom Krowka
PUBLISHER PROBLEM
Cannot publish layouts to dwg. When I hit the options button, the sucka crashes. Have deleted the layout, recreated the view, recreated the layout. Crashes out every time. Consultants are waiting, I'm having another bad day.
Any suggestions would help.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
2 Replies 2
Erika Epstein
Can you publish the drawings from archicad and let them place on a title block sheet?
If there is more than one drawing, this method might at least help you narrow down to which might be the problem one.
Will pdf of the layout help in the interim?
Or dxf?
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Tom Krowka
I've done the pdf.s. They work. DXF does not work either. They'll make do until I can figure this out.
[email protected]
www.walshkrowka.com
