2006-10-11 04:52 AM
2006-10-18 12:29 PM
andyro wrote:Sorry for being late to this. But I guess we'll have to live with these issues for years to come. When is the first Revit translator coming? Or do we really believe that the dwg format will suffice? Or that Autodesk will bow to a true IFC implementation in Revit?
I am just having to get at this again. I had everything working pretty nicely in 9 (especially from Plotmaker), and now my settings/translators have to be rethought.
...Units, when exported from AC10, in feet (1 foot = 1 drawing unit)Well, yes. When you export you should always set the Drawing Unit in the translator to what you want it to be in the resulting DWG, to get a correct model space 1:1 drawing.
On opening in AutoCad, gives engineering units in decimal feet. AutoCad shows exported DWGs in decimal feet (when measuring/working). On changing units to 'Architectural' (fractional inches) - the whole of modelspace requires to be scaled by a factor of 12 - why? How can I export with architectural units so that rescaling is not required? (is it as simple as exporting 1 unit = 1"?)
...What I am after is a light, simple, clean DWG, with 'purged duplicates' as it were, and more or less WYSIWIG export/import. Why can't I 'purge' BEFORE export! (wish?)I hope GS is working on this. I also hope we get a 'total explode' setting back - I think there was one some years ago.
Images - why do some have frames, and others do not?No idea.
Pens - why do all pens, while preserving pen colours, never show anything but white pens in the layer list? Bylayer export doesn't change this. The convertpstyle tricks also haven't remedied this....has something to do with everything being blocks, not actual linework.I guess you mean the pen list in Autocad? If so I don't know. But I've run across a similar issue when I'm importing into Archicad. I've solved that by have two identical pen tables with different names. If I switch between them, the colors come back.
As I am not an AutoCad user, forgive me if I sound like I am talking out of my a**, I am. But I am just repeating common complaints about my 'inferior' ArchiCad DWG export, and I'd like to get to the bottom of all of these issues. Your thoughts, elucidations are valued. Thanks in advance!Thanks for this initiative, Andyro!
2006-10-18 02:19 PM
2007-01-29 09:11 PM
2007-01-29 10:54 PM
andyro wrote:Or Stockholm Syndrome, perhaps...
Thanks for the ray of Stockholm sunshine😉
2007-01-30 09:19 AM
2007-01-30 02:19 PM
2007-01-30 07:11 PM
kliment wrote:Perhaps when US currency is no longer the international standard?
When will I be able to ask for drawings in pln?!?
2007-02-02 07:20 AM
andyro wrote:Ever heard of Euro?kliment wrote:Perhaps when US currency is no longer the international standard?
2007-02-02 02:04 PM
