2019-03-22 02:23 PM
Solved! Go to Solution.
2019-03-26 09:43 AM
2019-03-22 07:45 PM
2019-03-25 11:33 AM
2019-03-25 09:20 PM
2019-03-26 09:43 AM
2019-03-26 02:30 PM
Erwin wrote:It's ok with the national coordinates and the corresponding dwg. I can then move it to the project origin by using the dwg.
As far as I know you can either place point cloud with its origin to your origin or specify on screen where you would place its origin.
So if you know the real world coordinates of the point cloud (ask the company that made the scan) you can then place something like a hotspot or survey point object at this coordinate in your model. If you then place the point cloud by specifying the place, you just need to click on that spot.
That leaves north direction, so you will have to rotate it after placing.
Edit:
Actually if they can specify 2 or 3 points and you can identify them as a snap point in the point cloud you would be able to get north direction correct too.
