2011-05-17 10:54 AM
2011-11-25 04:56 PM
2011-11-25 05:07 PM
2011-11-25 06:39 PM
afingret wrote:On another level, the problem with point clouds in the Architectural environment is that so many of those billions of points carry little or no data of interest. That's why edge-finding (& line substitution) and vertex-finding, and other point reduction techniques are so important if the surface polygons are being built up from primitives. These operations would likely best be carried out on an initial pass outside BIM software, or by an add-on as you suggest.
The problem with point clouds is that they are usually massive in nature (often billions of distinct points) and would choke Archicad if you tried to import them directly. It may be theoretically possible to convert a point cloud to 3d hotspots in AC, but I don't think it will be easy to work with. Archicad just isn't geared for handling that many objects at a time....
2011-11-25 07:32 PM
Direct fit of likely solids to point clouds, as opposed to trying to generate a solid from a set of points, will benefit from user input. Where that user-input should take place reflects a changing assessment of what's practical.
2011-12-09 04:53 PM
2012-04-04 08:08 PM
2012-04-05 10:10 AM
2012-04-05 04:38 PM
2012-04-09 05:40 PM
2012-08-22 11:56 PM
