2015-12-29 05:33 PM
2016-01-03 09:38 AM
2016-01-03 04:14 PM
2016-01-03 08:41 PM
2016-01-03 09:08 PM
2016-01-03 09:28 PM
2016-01-03 10:55 PM
2016-01-05 03:32 AM
Olivier wrote:Kind of.
When creating an accessory object I saw that I could select Polyline accessory as a subtype. Does that mean that we can attach those objects to polylines as it is possible with Slabs ? How then ?
Thanks for any help.
2016-01-05 05:19 PM
sinceV6 wrote:I have started this, I almost have it working with your original polyline.
Hi.
I haven't had the time to dig a lot into this. The easiest way to see it in action is to make sure you have the accessories library loaded, create a polyline (with the polyline tool, not connected/grouped individual lines), select it and apply the polyline accesory object: If I remember correctly, only a footing object is available in the library. Once placed, you can change the polyline nodes and the object will follow accordingly, arcs and all. You can even place it to several selected polylines in one go.
It seems that the subtype will get the polyline node's coordinates, and you can use that to script your object. You could also invoke the accessories command without a selection, and this will allow you to place the object like drawing a polyline, but it'll be static once done.
It could be helpful for some types of objects, specially for FlatLandia (a place where AC likes to hang out), cause I'm guessing that Z elevation would need some more parameters, arrays and scripting to make useful objects.
Best regards.
2016-01-05 06:14 PM
