Hi Dale,
of course I should see your file in order to help you...
Anyway what I can say without doubts is that ArchiTerra doesn't save any object in binary mode.
The tools used to modify the terrain are parametric objects so they are not created but just inserted with the proper parameters setting (so no object creations during the terrain modification).
The only object saved by ArchiTerra (BTW in the embedded library) is the one used to display contour lines and color depth, but in this case is a GDL object (you can open it and verify my words).
Friendly
Fabrizio
Fabrizio Diodati
