2006-03-15 04:35 PM
2006-03-15 08:05 PM
2006-03-15 08:10 PM
2006-03-15 08:20 PM
SmileyMan wrote:do you have administrator rights on your machine? You may not have the permissions needed to install software in that directory.
I saw that too. However, if you look at my Finder bar behind the Graphisoft green window, you can see that I have "90.67 GB available". My hard drive properties say the same thing.
2006-03-15 09:00 PM
2006-03-15 09:06 PM
SmileyMan wrote:I wondered about that but could not figure out where it came from.
Yep, got Admin Rights
and got the Mac version.
One thing I noticed is that the folder separation in the program is a slash "/" as separated in windows, NOT a colon ":" as Macs normally separate folders. You can see that once I created the Application folder "sketchup", the program correctly set the file structure as "....Add-Ons:sketchup", but did not correct the previous portion.
2006-03-17 10:50 AM
2006-03-17 08:44 PM
2006-03-19 04:27 AM
SmileyMan wrote:Therefore, ALWAYS include in your signature your hardware and OS description ...
To Everyone:
I finally got the problem fixed. A Graphisoft Tech here in the US figured out that the SketchUp Add-On will not install on the new MacTel computers. The MacTel computers run the OSX software differently than the normal G5's.
His solution was creating an .sitx file for me of all the files. I downloaded them and placed them myself in the Add-On folder. That worked!
Thanks to everyone for their suggestions!
2006-04-04 11:34 PM
