Project Reviewer
Does anyone use project reviewer effectively and care to comment? I would like to work more remotely with my office.
Thanks
12 REPLIES 12
we use a laptop...which is great...I can preload everything...all need is a connect.....I also just discovered that you can import this into you RedLines....I am exploring this a little bit more....
Same here, I also love the -e-mail redlines- option.
The major benefit is the CONCEPT that the client only needs a browser.
In reality you have to set it up for the client, like the e-mail options can't be stored with the project on the server, so you have to do a dry run with each client to make sure it works.
So when it works-great, but when it doesn't, it's pretty hard to bring it to life. The Java applet gives little clue about why it hangs. Troubleshooting info is scratchy.
ricki_faris wrote:
I have a similar query - testing how redlined DWF files from the Reviewer can be imported back to ArchiCAD for amendments.
I've done these steps and been able to select the redlined DWF file, but no elements appear at all....
Any help appreciated...
Ricki
I'm having this same problem
anyone?
