‎2019-05-31 10:29 AM
ARCHICAD 19-25, Student & Full Archicard, CI Tools, Germany
Mifcom Renderbox AMD Ryzen 9 5900X GeForce RTX 3070 TI 32GB RAM 980 PRO SSD Win10
Thinkpad P52 4K i7 8850H NVIDIA Quadro P3200 (6 GB) 32 GB RAM SSD Win10 Pro
‎2019-06-03 12:21 AM
‎2019-06-03 07:58 AM
‎2019-06-03 04:09 PM
‎2019-06-03 04:49 PM
IF ( ISUNDEFINED ( {Property:OPENINGS/Fire Exit} ), TRUE, FALSE )
will correctly return "TRUE" when the "Fire Exit" Property is <Undefined>, and return "FALSE" when the "Fire Exit" Property is either TRUE or FALSE (not <Undefined>). The "Fire Exit" Property has the "True/False" Data Type.IF ( ISUNDEFINED ( {Property:GENERAL RATINGS/Fire Resistance Rating} ), TRUE, FALSE )
will always be evaluated as "FALSE", regardless of whether it is default (Undefined), is set to Undefined, or set to any other value. The "Fire Resistance Rating" Property has the "Option Set" Data Type.‎2019-06-04 06:57 AM
‎2019-06-07 02:05 PM
256527 DOCUMENT: ISUNDEFINED function of the Expression-based Properties was not evaluated correctly for Option Set type Properties.
‎2019-06-08 10:16 PM
