2020-02-11 08:53 AM
2020-02-12 01:47 AM
2020-02-12 08:52 AM
2020-02-12 09:10 PM
2020-02-26 09:18 AM
LaszloNagy wrote:That is our current solution. The downsides are, that you need a Dropbox PC with all the files, that is sharing them. This solution has some problems.
Yes, if the Dropbox folder is not under the User's Profile folder then others will probably be able to see it.
On each computer, in Windows Explorer, select "This PC" in the list, then use the "Computer>Map Network Drive" command on the Ribbon.
Map a drive letter (such as drive "Z:") to the Dropbox folder (e.g.o "Z:" and it will always publish into the Dropbox folder of the current User.
Let me know if this works.
