Quantities of skins for composite walls
Hi!
Is There a way I can show quantities of each skin for composite walls, in wall list schedule?
Thanks.
1 REPLY 1
A 'component' schedule can show information on each skin. See attached screenshot for fields available in Scheme Settings dialog. Note that this lets you schedule the skins of complex profiled elements too - a 'composite skin' is the same as a 'component fill'.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
