Regarding Door Schedule
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-05-20 05:01 PM
2019-05-20
05:01 PM
1. Is it possible to change orientation title L/R to another language?
2. Is it possible to get a door view from the side without surface colors, just outline?
Thank you!
Labels:
- Labels:
Data management
7 REPLIES 7
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-05-21 03:03 AM
2019-05-21
03:03 AM
As far as I know, the only way to do this is to edit the door object.
But if you do this then you may want to 'Save As' the object with a new name, otherwise it will all be undone should you ever update the GS library.
For this you need to set up and use a Graphic Override in your schedule view.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-05-21 12:14 PM
2019-05-21
12:14 PM
Barry, thank you for your prompt response. Graphic Override works perfectly! However, Orientation Displaying does not change in the schedule.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-05-23 11:49 AM
2019-05-23
11:49 AM
Does anyone have an idea of how to translate door orientation title L/R to another language in the schedule?
As you can see from my images, Custom changes in Orientation Displaying of the door object do not work in the schedule.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-05-24 03:15 AM
2019-05-24
03:15 AM
Dalius wrote:I just tried in 22 and no, it doesn't seem to work.
I am sure I did it some time ago in a much earlier version.
Even swapping from default to reversed seems to make no difference - when surely it should otherwise why is it there.
I also just checked the Registry (Windows) for abbreviations.
I can see the ones for North (N), East (E), etc., but none for Left & Right.
So I have no more ideas sorry.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-05-24 03:26 AM
2019-05-24
03:26 AM
I just tried it in an older version (16) and it works fine there.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-05-24 04:07 PM
2019-05-24
04:07 PM
Workaround: create a property. Data type String.
Use expression:
You can then schedule this property instead.
Use expression:
IF ( {Property:Window\/Door/Orientation} = "L"; "your bit of text for left"; "same but for right" )Make sure to assign it to 'all' (or doors and windows etc, but I'm lazy so I tend to pick 'all' for classifications).
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-21 04:51 PM
2020-04-21
04:51 PM
Erwin, that’s so great! Thanks a lot!
Regards,
Dalius
Regards,
Dalius
