2008-09-18 10:37 PM
"From a conceptual and philosophical perspective, BIM is a better way to design, construct, and manage buildings. It allows architects to design more efficiently, construction firms to better manage costs, and owners to stay on budget and control day-to-day operational costs. BIM fulfills the promise
of economic gain and also better business relations. Excessive change orders, resulting from communication errors or missing information, negatively reflect on owner’s perception of architects and construction firms. Architects and construction firms with a reputation for costly overruns tend to lose business.
"As the key technology shared between architects and construction firms, CAD applications have taken center stage in the movement to take BIM mainstream. CAD’s ability to capture and represent the geographic information, building geometry, component relationships, and quantities and
properties of building components is at the heart of BIM. Several CAD vendors tout their applications as central to the BIM process, capable of managing the complex 3D information model generated on a BIM project. But are they really? As BIM evolved, architectural intelligence was built on top of primitive foundations. Many BIM applications have limited functionality and key elements of the model cannot be represented in 3D; most do not have a modeling kernel reliable or fast enough to handle large, detailed 3D models. Without the efficiency of a purpose-built 3D modeling kernel, good visualization becomes an extremely time-consuming process.
"We have the answer to BIM’s technological problems: adopt the time-tested platform used by the MCAD industry to build the best architectural 3D CAD solution available. With a purpose-built 3D modeling kernel, Vectorworks 2009 manages building complexity which previously tested the limits of
most BIM applications."
But then, Boingo:
At the Nemetschek Press Event, Ralph Grabowski reports this about Jim Flaherty's keynote theme which is
"BIM Isn't Happening...
...because it costs architects to implement BIM [building information modeling], but they do not get paid more for using it. (In the row ahead of me, Ed Goldberg was vigorously nodding his head in agreement.) Architects want a payback for themselves; they care not if the owner saves money down the road with BIM, because architects don't get any of that savings paid back.
"The key strength of Vectorworks is its free-form modeling, which products like Revit can't do. Mr Flaherty is pleased that Autodesk helps out Vectorworks by marketing BIM and Revit -- but then ends up selling AutoCAD.
"For five years, the #1 selling point of Vectorworks has been its presentation graphics -- outputting good looking drawings with gradients, transparency, 2D Booleans, and non-photorealistic effects in 2D and 3D. All this generated within Vectorworks, again something competitors can't do.
"Now there is a new key mission: Design. Mr Flaherty segregates design into four steps:
I. 2D.
II. 3D Conceptualization or Visualization.
III. Integrated Design and Development.
IV. Model-centric BIM [building information modeling].
Most customers are at step II, 3D Conceptualization; he's trying to get users to the next step, Integrated Design.
Step IV? It's a long way off. Model-centric BIM is the future that everyone talks about today. But there are lots of holes in the process, such as legal issues. Today, BIM works only for owner-builder-operators, such as GM building its own plants.
So, what are some of the limitations of competitors -- Revit, in particular?
* Modeling limitation; freeform modeling is needed to design things like spline-shaped roof edges. Vectorworks is the only one with NURBS surfaces.
* 3D speed and robustness; purely parametric modelers can't handle the model size once details are added.
* Complex UI; users face varying user interfaces when they switch between 2D and 3D packages from the same vendor. Vectorworks has the same UI for all its software.
* BIM slows down design; users spend too much time wrestling with the system.
* Good visualization is hard to get; customers find they have a hard time reproducing the beautiful renderings pictured on the vendor's Web site.
Mr Flaherty sees BIM as something that excites accountants, but not architects, and thinks that paper drawings will be the preferred output method for his lifetime -- as opposed to exchanging drawings electronically."
see the whole article at Issue #572 : : Setpember 16, 2008
http://www.upfrontezine.com/2008/upf-572.htm
Seems Mr. Flaherty has a different idea of what BIM is. His approach seems to be to say, everyone else's ideas about BIM are wrong or wrong headed. And then to take BIM back to CAD circa 1993.
2008-09-28 05:25 AM
2008-09-28 05:42 AM
Dwight wrote:When you put yourself out there as a Revit spokesperson and Bim expert you need to know what you're talking about,I would have thought Autodesk would have checked this persons credentials?
WES MACAULAY is hereby pronounced to be not-a-duffus when it comes to BIM, so lay off.
2008-09-28 06:01 AM
2008-09-28 08:42 AM
2008-09-28 03:04 PM
2008-09-29 03:46 PM
2008-09-29 05:13 PM
2008-09-29 06:02 PM
2008-09-30 12:19 AM
2008-09-30 12:44 AM
One thing that came as a shock is that AC users don't have a working grid tool! They've got a beta version of it, but it evidently sucks mightily.And here's a quote from my thoughts on AC12:
I also suspect the AC is more scalable -- it can handle larger projects, and can create more curvaceous geometry what with the bundling of Cinema 4D with AC (if you buy the combo -- kinda like AutoCAD Revit Architecture Series).
But as Fernando said, AC is perhaps more "manual" in its approach; change storey heights and you've got to redo all the wall heights on that storey.
I've got AC10 on my computer here and there are many more dialogs to plow through to get things done. Also, you have layers to manage which AC users tout as a feature, but it merely means more management, since you can put walls on the furniture layer. Assemblies aren't listed as such -- they're called 'Favorites' in AC and are more complicated to set up; you set up what layer your favorites will go onto when you use them. Revit's notion of categories is far more elegant and AC should have stolen that idea long ago. Attached walls don't automatically re-trim themselves to the roof when you change the roof... and so it goes. It would be a lot harder to learn than Revit. But if you are dead-set against using Windows (even in VMware or Boot Camp) AC is probably the best BIM app out there for the Mac.
Originally Posted by iandidesign:Al-Qaeda does better video.
Quote of the day, perhaps?
Glad to hear that life in AC is a bit faster than minutes. And I would hope that Graphisoft and AC are raising the bar of their software -- imitation is the sincerest form of flattery after all!
