Revit model in Artlantis?
I have created a building Revit 8.1 and wish to render it using Artlantis R, will this work, or is there a conversion program I need?
Any light on the situation would be greatly appreciated.
Thanks
Nessy247
3 Replies 3
Dwight
It should.
Does your application have an ability to export its 3D window in Artlantis format?
Perhaps you will need a plug-in or something.
I am sure the guys over at the Revit forum can help you better than we can.
Dwight Atkinson
Although this is not the right forum to ask this question, I think Revit 8.1 had very few export format available. Probably has more since but that version was lacking in that aspect.
Djordje
try 3D DWG, DXF or 3ds. If Revit has those options - it would be surprising if it did not.
Also, ask Artlantis related questions in Artlantis forums, on www.artlantis.com
Free registration is required.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
