Room Schedule issue
I am making a room schedule on some floor plans and just need to list Room #, Room name, and the area of the room. I have it set up, but for some reason the areas are displaying strangely. For example, if a room is 50 meters squared, rather than showing as 50 m2 or just 50, it sometimes will show up as 50^2 or 50^8 or whatever. Any ideas why it's doing this or how to fix it? I've attached an image to show what it's doing. Thanks
3 Replies 3
Eduardo Rolon
Check under Project Preferences the settings for Dimensions and Calculations
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Eduardo Rolon
and the other one.
If I remember correctly for the dimensions settings that can/should be saved with the View of that particular schedule.
AC29 US/INT -> AC08
Thanks for the help. I was able to fix it by setting the "Extra Accuracy" dropdown in the area calculation preferences to "Off".
