2021-03-1908:08 PM - last edited on 2023-05-2603:07 PM by Rubia Torres
2021-03-1908:08 PM
Hello, Can someone explain what is The new saf format and analytic model, presented in archicad 24 ? The benefits of the tool. Why it's cinsidered a revolution in archicad? Who uses it, who prepares the analitic model, for what, When i have a new project, when it comes to the scene, etc I think It's a little bit dark side in archicad that should be explored and explained well. Is there any case studies ? Thanks !
Here is the playlist from the Archicad YouTube Channel, which talks about the new features in Archicad 24.
Clips 4 to 7 talk about the Structural Analytical Model features. I think it gives a basic understanding of what it is about, what is its significance, how it works, and how it enables collaboration with Structural Analysis applications:
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
Thanks LaszloNagy !
this video serie introduces the concept, without some deep demonstrations, how does it work in a real project, with other softwares, real action
One of the videos shows an example of how such a structural analytical model exchange would happen between Archicad and SCIA (a Structural Analytical software within the Nemetschek Group):
I think it gives you a general idea of how it works and how you can use the data received from the Structural Engineer to modify/update your architectural model.
Besides that, I have not found a longer video on the net that would show the workflow in more detail.
