DennisAndreoli
Save model with custom profiles as .dwg
Hi all,
Version: Archicad 27
I am relatively new to Archicad, so I am sorry if the following question is a silly one. I just could not find an answer to it, hence this post.
I am using Archicad to create the basis for a VR environment. I am trying to save a model as a .dwg format. In this model, I make use of columns with custom profiles. These columns therefore consist out of a variety of materials. When I save the file as .dwg however, the different materializations in the custom profiles are ignored and it outputs a model where the complete column is one single object. Is there a way to save the model as a .dwg where these different materializations become different objects?
Thanks in advance!
Kind regards,
Dennis
Try this:
1. Save a copy of the file.
2. In the saved copy, convert all elements with these Profiles to Morph.
3. Export as DWG, see if that preserves the materials.
