Steve Jepson
Saving Schedules as
http://www.graphisoft.com/ftp/publishing/ac12_help_USA/Files/wwhelp/wwhimpl/js/html/wwhelp.htm
"Saving from a Schedule Window (Interactive Schedule)
Schedules can be saved in the following formats: Tabbed text, DWF, and PDF. From a PC, with MS Office, you can also save in .doc and .xls formats."
How?
I can open the .xml file with Excel but it sure does not look very useful.
6 Replies 6
When you're in the schedule window, go to File>Save As, and you will see a variety of formats. XML is not one of them.
Richard
AC26 (since AC6.0), Win10
Steve Jepson
Thanks. I was confusing XML with XLS. I should have known that was too good to be true.
I was trying to click on File > Save As, but nothing happens when I do that.
The screen blinks just a little like it was going to open the Save As window but nothing happens. I have checked to see if the save window is open somewhere I can't see it but its just not there.
I will try a fresh file. This is an older Beta file saved as a 12 2156 .pln
Steve Jepson
There it is. It must have been the file I was using.
Steve Jepson
It worked one time. Just after I saved the screen shot above I tried it again and the Save EIS screen will not come up again.
You need first to save any old beta files with the RC1 or RC2 beta, I believe. You can't just open and save an old beta file with 2156. The file could be corrupted at this point.
Richard
Steve Jepson
The name of the Schedule was 8" Foundation Walls.
The " was the problem.
It should have a pop up that says the file name is not valid.
