Scales in Drawing list
On several sheets in my set I have a drawing at scale 1:200 and a room schedule (which I suppose is at 1:1). When I make a drawing list on my cover sheet, in the scale column for these sheets, both 1:200 and 1:1 are listed as the scale for this sheet. How do I make it not show the "scale" for the room schedule? Is there something in the settings for a view that makes its scale not appear in schedules or indexes?
1 Reply 1
Eduardo Rolon
AFAIK if you define the column AC will fill the scale for all the drawings and there is no way to exclude it for schedules
The easy workaround is to draw a White Fill on top to "erase" the item.
The other is to create an Index for Drawings that list the scales and create another for Schedules only in which you don't include that parameter.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
