Schedule Problems
I have a Interactive Schedule that we have created to list out our doors and windows with some custom parameters. This worked OK. I have two problems I need help with.
1. I have some D&W that I don't want listed at all. Even if I leave the ID field empty it still gives a quantity. Is there a way or check box to exclude this from being listed.
I want to include Skylights in the schedule without making a seperate one.
2. The attached shows my scheme settings. Why is there not an Element type available for Skylights? When I add parameters to look for the skylight object also, the D&W's don't show. Any ideas on how to get this working? It looks OK to me.
Chris
AC10-1010
AMD Athlon 64 Dual x2 4800+ 2G ram
5 Replies 5
TomWaltz
I usually give elements I do not want to include an ID of "skip", then set the schedule to use Element ID <> "skip"
I cannot say about the Skylights. I never realized they were not listed and don't have an immediate thought....
The reason your doors & windows do not show is that you are telling Archicad to only include doors & windows with a certain object name.
Tom Waltz
Thanks, Tom
I'll edit my sched as you suggest. I wasn't thinking like that but it makes sense.
I thought it may be working like that but the criteria says "window or door or object...the way I read it. I'll keep trying to see if it can be included in my list. I should be so much easier than this.
Chris
TomWaltz
Chris wrote:
Thanks, Tom
Chris
Look closer. It's actually:
Element Type = (Window OR Object OR Door)
AND
Object name = "Skylight top hung 10"
It's sad to say. but schedules are not terribly inclusive. They often work better if you include a little too much, then tell it how to back off.
Tom Waltz
AND
I am trying this now, but this doesn't work either. there seems to be no way to get a skylight to list in a door and window schedule.
Oddly, a skylight is not even in the list of tool types to schedule.
Anyone work around this without manually adding info into a proxy opening in the schedule?
Yes, you're right. Tom's suggestion does not work - it would only list elements whose name is that particular skylight.
Given the limited logic options in AC 12 and earlier, it is not possible to get windows and skylights in the same schedule without other tricks, such as filtering by the ID field (one example). If only windows and skylight ID's start with W, for example (perhaps WS for a skylight), then filtering by elements whose ID starts with "W" kind of works...to get a mere list/quantity. But, it will not display the sizes the way one would want because skylight objects use different data fields than window objects. See attached.
Karl
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
