Artlantis Export Add-on Problems PLEASE HELP
I downloaded the Artlantis export from the artlantis website. Once installed, it is now telling me that it is an outdated add-on and can't be used. I had the same problems with my old PC, but I just switched to an intel MAC and was stumped to find the same issue. Graphisoft was unable to halp me with my PC, so I came here to see if anyone knew what was going on. My friend has a mac as well (power pc) and his works fine. Please Help
5 REPLIES 5
Dwight
Is it possible you inadvertently downloaded the wrong thing?
You want MacIntel.....
Dwight Atkinson
yea, i'm positive that I downloaded the MacIntel version because I did it twice.
Dwight
there's your problem.
The two copies cancel each other.
Just kidding.
Is Archicad confused?
Is it possibile it is seeing another Plug-in from the old days?
Check your Add-On Manager.
Dwight Atkinson
I did check the add-on manager, that's how I know it's telling me that it's outdated. If someone knows where I can find the right one let me know because the one from artlantis isn't working for me.
Djordje
Read the previous topics on the same issue and you will probably end up with a big slap to your forehead ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
