ā2016-07-28 06:06 PM
ā2016-07-28 06:10 PM
ā2016-07-28 09:55 PM
jameshart wrote:Lets start with this one.
Also, what are the little superscript numbers? And how can I reduce the number of decimal points? I thought changing the dimension settings (US Architect, US Builder, etc.) would change this, but so far it is not.
ā2016-07-28 09:59 PM
jameshart wrote:I am not sure what the intention here is. What does a column need to show? 615, 615, 629 instead of 14139, 615 and 1259?
Is it possible to tell the schedule to show the area in that column PER UNIT instead of COMBINED?
ā2016-07-28 11:12 PM
Anton wrote:Extra accuracy was it, thanks Anton!jameshart wrote:Lets start with this one.
Superscript represents "Extra accuracy". (search the online help for the keyword if you need more info).
The changes you need to make are not related to dimensions.
They are related to calculations and schedules and are located here: Options > Project Preferences > Calculation Units and Rules
ā2016-07-28 11:31 PM
Anton wrote:I'm trying to setup a schedule that will generate the unit chart that we use to make manually in Excel.jameshart wrote:I am not sure what the intention here is. What does a column need to show? 615, 615, 629 instead of 14139, 615 and 1259?
ā2016-07-29 09:53 AM
jameshart wrote:
How can I create column column 2?
ā2016-07-29 06:07 PM
To get it straight, I assume we are talking about AC18 in your signature, as other ARCHICAD versions will differ in this area.
So, initially, you have a schedule that looks like the top one (see image attached).
Then, you check "Merge Uniform Items" and the schedule contracts to look like the one in the middle.
Finally you want a schedule to look like the bottom one, by adding the second column with a typical area of a unit?
Right?
ā2016-08-02 01:14 AM
jameshart wrote:I don't really like short answers.
Yes, absolutely! How did you do that? š
ā2016-08-02 01:15 AM
