We value your input!
Schedule for morph (length, width, section view)
I have elements by morphy (made by union, substract), but in schedule, no data is shown (length, width, section view). How can I schedule the data for morph?
Thanks
Morphs can be any shape or size so they don't have regular length width height.
They only have volume by storey, projected area by storey.
8 REPLIES 8
Thanks Barry,
ALso, the section view looks veird, how to show a reasonable views (section or plan whatever)
You may need to stretch the height of the schedule rows as the section may be bigger than the row height.
I am also unsure if it will show a true section through the morph or if it might just be a 'sample' cross section.
Hello Barry,
Yes but after streching the row hight, I need to show another direction of cross-section
Any advice how to set another cross section direction
Thanks
You can't unfortunately.
It is just a 'preview' of what the morph would look like in section - to show you the material colour and hatch pattern.
It is not an actual section of the morph.
Even the 3D Axonometry only shows a sample cube.
Hello Barry,
OK, so can I try another way say save these morph into library object, then creat details (3D, section etc) from library object? (and how to create working sheet about libray object details? I cannot find any tutorial on the web)
Thanks
Yes objects can display a section, elevation, plan & 3D view in a schedule and they will show the exact object and not a preview.
You still can not determine where the section is cut or and the front view (for example) is always the front of the object rotated at zero degrees.
So you could save your morphs as objects.
Place the objects in you model and then schedule those.
OK Thanks Barry
