2006-11-28 11:20 PM
2006-11-29 05:07 PM
2006-11-29 05:43 PM
				2006-11-30 03:09 AM
2007-02-11 03:22 AM
2007-02-11 07:00 AM
2007-02-11 03:22 PM
2007-02-11 06:00 PM
cremsberg wrote:Seems to me that you've found the best method (until GS makes it possible to change the layer combo in the schedule's view settings). It doesn't seem like much of a problem.
Here is a work-around for getting the layer settings as desired for schedules, so that fields are editable. With other View Map views, it is possible to edit the layer combo in the settings window. Since zones don’t allow this (at least not for me), try this: Open the desired schedule. Set layer settings as desired (I use show & unlock everything). Save into View Map as a new version of the schedule. Delete the old schedule.
This seems to work without too much hassle and I can set my template this way. However, if there is a better method, I’d love to hear about it.
2007-02-11 11:22 PM
2007-02-21 01:46 AM
Link wrote:What I meant was the ability to directly open an object's dialogue WITHOUT having to visit the item in the floorplan first....
The 'Select on Floor Plan' button....
