Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Schedules Search Criteria and Find Command
fuzzytnth3
In AC22 I have found that if you try to add an IFC Property as a search criteria in a Schedule or the "Find" command it immediately crashes ArchiCAD
Anyone else have this problem or is it just me?
Using AC25 5005 UKI FULL
3 REPLIES 3
Hello,
I do not see this type of problem on my AC22 version
I am working on macOS 10.13.6. Did you update your OS?
When AC crash I delete the Graphisoft .plist files from the finder in the folder library / preferences and library / application support
And then I restart AC but about your problem it seems to be more special
Perhaps it deals with your demotion to 10.12. How do you do this ?
Did you have installed AC22 before or after ?
Christophe - FRANCE
Formateur Archicad indƩpendant Ơ NANTES
Archicad 15 to 29 FRA FULL
There is a Find & Select bug that seems to have been fixed in the build 6000 update, which is in preview at the moment.
https://archicad-talk.graphisoft.com/viewtopic.php?f=10&t=66620&start=10#p298287
The general release version of this update should be available in a few weeks, but you may be able to try the preview in the mean time.
fuzzytnth3
Thanks for that info :thumbsup:
