Schedules Spreadsheet Calculations?
Gus
Is there a way to edit schedules so that they can calculate sums etc. as one does in a spreadsheet program?
I have some data on the schedules that I would like to find totals of. For example I have the area of all the windows in a room presented in the schedule I am making, and what I would like to do is add a "totals" cell to that spreadsheet that will total up the window areas as I work on the design so I can maintain the same amount of light that is coming in to a room as currently exists in that room. Is there a way to edit these schedules so that they can calculate sums etc. as one does in a spreadsheet program?
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
4 REPLIES 4
Any scheduled fields can be summed and/or grand-totaled. See the Help for selecting the summation (Greek Sigma) on the line for the scheduled parameter in the Schedule Scheme.
ArchiCAD cannot do any other / free calculations in the interactive scheduler - you'd have to export to Excel. See these old duplicate wishes on the more general calculation issue:
http://archicad-talk.graphisoft.com/viewtopic.php?t=33203
http://archicad-talk.graphisoft.com/viewtopic.php?t=21689
AC 29 USA and earlier   •   hardware key   •   macOS Sequoia 15.7.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Gus
Awesome,
Great tip
Thank you.
Is there a way to make the communication between excel and archicad automatic? I know this is a long shot but I thought I would ask. Wishful thinking.
Madison WI
Not quite automatic ... but you can create a Publisher set of the schedule(s) that you want in Excel and set the publish properties to save as Excel. If a separate, master Excel sheet does the calcs by referencing this external sheet, then the results will automagically appear there when that sheet is opened, or refreshed.
Gus
Karl,
I think I got it.
That is pretty slick.
Better than I thought it would be.
I will give that a try.
Thank you so much for your help.
-Michael
Madison WI
