Ruben V
Scheduling lines?
Is there any way I can schedule "Lines" in Archicad? I would like to measure lengths, but they don't show in the element type dropdown...
A possible workaround is probably using Morph-lines...
(òÓ,)_\,,/
www.studiov2.be
Archicad 26/27 + Rhino/Grasshopper
BIMcollab ZOOM
>>> Read my book!<<<
3 Replies 3
Ruben V
Just tested the morph-line - only volume/area/... are possible properties to be listed.
(òÓ,)_\,,/
www.studiov2.be
BIMcollab ZOOM
>>> Read my book!<<<
runxel
Sadly, thats not possible.
GS doesn't consider this as "BIMmy enough".
sinceV6
Hi.
Depending on what you need it for, remember you can have zero width&height walls and beams that you can then schedule. Walls like this will display in 3D as lines, beams won't, but you can set them to a very small value and they will show.
Best regards.
