We value your input!
Sketch up import
How do i import a sketchup file into ArchiCAD
42 REPLIES 42
Just that he had as close a connection as one might have with the CEO, Dominic Gallello, and what is the inside story on the GS-@Last connection.
http://www.graphisoft.com/company/press_zone/press_resource_kit/opboard.html
From the outside, it is rumors only...
How do I export ArchiCAD file to Sketch Up?
Dwight
ONE WAY TICKET.
The train goes downhill......
nocando.
Dwight Atkinson
stefan
Export as DWG/DXF from the 3D Window.
Insert in SketchUp.
Archicad-user since 1998
my Archicad Book
Dwight
but no meaning to it.... just blocks...
Dwight Atkinson
Insert in SketchUp.
The reason for exporting (although it will turn to block after export to dwg format) is that I don't know how to use Sketch Up, so if I build the 3d model using archicad myself and my workmates can work on it after i have exported the model to SKetch Up
Eduardo Rolon
And Why would you do that?
Anyway learning SU is easier than learning AC.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Dwight
"And, Eduardo, you are forgetting that it makes Architecture into a video game! Again! "
Sort of like when ArchiCAD first came out.
[Smile]
[Hold polyethelene wrapped CD toward camera.]
Dwight Atkinson
Quote from SketchUpDate below...
This -in theory- means that you can export your latest Skup model into version 3.x and that can be imported into ArchiCAD version 8.1 via the skup2ac81 plugin (my baby:)
once saved as an ArchiCAD file it supposed to be readable by AC9..
AC8.1 supposed to run with the AC9 key.
"In theory there is no difference between theory and real life. In the real life there is..."
Hello SketchUp Users,
A new SketchUp build is now available for download! We
strongly encourage you to download this build as it contains a
feature that allows 4.0 files to be exported to version 3.x and
several bug fixes that have been causing SketchUp to crash.
Latest Builds:
Windows - 4.0.170
Mac - 4.0.173
In real life how much is one bound to loose between the tranfers from Upper to lowwer versions across another applications then again to a higher version?
