2004-06-09 02:44 PM
2004-10-30 02:04 AM
2004-11-10 01:56 PM
2004-11-10 02:23 PM
2004-11-10 02:43 PM
yffchan wrote:Export as DWG/DXF from the 3D Window.
How do I export ArchiCAD file to Sketch Up?
2004-11-10 02:55 PM
2004-11-10 03:03 PM
stefan wrote:The reason for exporting (although it will turn to block after export to dwg format) is that I don't know how to use Sketch Up, so if I build the 3d model using archicad myself and my workmates can work on it after i have exported the model to SKetch Upyffchan wrote:Export as DWG/DXF from the 3D Window.
Insert in SketchUp.
2004-11-10 11:21 PM
another Moderator
2004-11-10 11:50 PM
2004-12-08 04:31 AM
2004-12-08 07:37 AM
"Ferenc" wrote:
"In theory there is no difference between theory and real life. In the real life there is..."
In real life how much is one bound to loose between the tranfers from Upper to lowwer versions across another applications then again to a higher version?
