2005-12-07 02:44 PM
2006-01-10 08:44 AM
Daniel wrote:I think that you should avoid to draw walls as two faces in SketchUp.
well I'm still waiting for my magical computer that will import finished archiCAD models from the design I've draughted out in my head
but.. for the time being, I got this plugin today, and I've just been fannying about, and the whole "each face is a wall" thing is.. well.. quite annoying, I havent taken a look at the user defined rules import feature, but is there a way using this to make it import a vertical surface with a thickness as a wall. in sketch up is I draw a 120mm wide wall... can I set the importer to know that a vertical object of 120mm thickness is one wall? or am I way off base?
cheers,
dan
2006-01-10 12:01 PM
2006-01-10 02:32 PM
Thomas wrote:This is the method I typically use, but I still think it would be nice to have the direct import capability. In regards to making walls a single face... how do you do this in sketchup? you can't exactly extrude a line vertically...can you?
i prefer to just export a dwg from Sketchup and import it as 3D object in Archicad. It gives me the whole free-hand freedom in Sketchup - i don't have to worry about correct dimensions etc (which has been the problem of computerbased sketching all the time).
2006-01-10 03:26 PM
Daniel wrote:I usually extrude the outer contours from a building, instead of drawing individual walls.Thomas wrote:This is the method I typically use, but I still think it would be nice to have the direct import capability. In regards to making walls a single face... how do you do this in sketchup? you can't exactly extrude a line vertically...can you?
cheers,
dan
2006-01-10 03:48 PM
2006-01-20 07:10 AM
2006-01-20 07:54 AM
TMCompany wrote:free. but for you? nothing...
How much is the SU plugin?
2006-01-20 09:48 PM
