Sketchup export problem
All my attempts to save the model to sketchup result in 0 bytes files, although the computer seems to work a bit to generate them.
I tried to make a simple new file but it didn't work either.
Does someone have the same problem?
5 REPLIES 5
I have the same problem! it sucks.
Eduardo Rolon
Just tried it and it works. Are you saving from the 3D Window?
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
We had a similar issue here in the UK with a client and it was caused by a huge texture 27000x4000 pixels in the ArchiCAD model. If we removed it or used one of the standard ArchiCAD textures it worked. Perhaps this is the same issue with your ArchiCAD model?
Can you please explain more ? I don't understand what you mean by" huge textures " and how to change them?
My building is made with aluminum and chrome and grass .. If that helps.
David Maudlin
You will need to look at the Surfaces used in the project: open the Attribute Manager, set to Surfaces, you will see a check mark next to the used Surfaces, if they have a Texture it will be listed in the Texture column. Then open the Surface Settings dialog box, change the Engine Settings to OpenGL, and check the size of the associated Texture in the Texture panel for each Surface used in the model (the size in pixels is above the Texture image on the right in parentheses).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
