Tom Krowka
Small .bmp export
How can I easily create a .bmp picture of a small portion of a floor plan in order to send it to a client.
Thanks
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
Place a marque around the around you want to show the client.
Click on the 3D button and rotate to the view you want to see.
I usually then render the picture as I don't want to show the square box in the middle of the picture.
Save AS: either a BMP or preferably a JPG image.
Grant
Djordje
Why BMP?
Set the view with the marquee, or set the marquee, print to PDF (use the Amyuni PDF writer you got with ArchiCAD if you do not have something else) using the Marquee option. MUCH better for emailing and looking at.
If you define a Publishing set, then you can generate the whole set at once.
HTH,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
