‎2010-04-11 12:26 AM
‎2010-04-11 03:17 AM
‎2010-04-11 01:11 PM
Erika wrote:So, because I know the dimensions of the building, will the " measure tool " work for getting the scale correct ?
So,
Place the map in archicad, in a worksheet as an eternal drawing. If you know the scale of the map, set the worksheet's scale to match.
If not, you may have to resize the map after it is placed using a known dimension.
From the library place the scale object.
Print the view, or place the worksheet on an A1 sized Layout sheet.
Publish.
‎2010-04-11 02:28 PM
