2025-08-15 08:34 AM
Is there a reference for adding custom fields anywhere? I want to add the "Scale" information to my titleblock template. The original template that came with the software didn't have this field included. I tried adding a text box with #Scale but it didn't work. Thanks in advance! ~Anita (newby)
2025-08-15 08:57 AM
You need to use 'auto text'.
Just add the auto text for Drawing Scale.
2025-08-15 09:04 AM
Actually, no that won't really work.
That auto text needs to be in the drawing view (i.e. your plan or elevation), not your title block which I assume is in the master layout?
If it is in the title block, it will give the scale of every drawing in the layout it seems.
2025-08-15 09:36 AM - edited 2025-08-15 09:40 AM
You can limit what shows there by checking a box in the Drawing Selection Settings. Just note that the orders seems to be determined by the order of placed views.
Not sure if there is a better way, but that is how I get my door and window schedules to show the scale for the drawings. I have a view placed at 1:50 off to the side and set the actual drawing to be ignored.
Ling.
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
2025-08-15 09:53 AM
That is great.
I like that.
I haven't noticed that before, but then I don't have the scale in my title blocks.
Each view (drawing) on my layout has its own title and scale.
