2020-09-25 08:19 PM
2020-09-26 02:51 AM
2020-09-28 05:52 PM
2020-09-28 08:14 PM
elina wrote:The only element-connected image I know how to place in a schedule (and I hope I'm wrong) is the GDL Preview Image, which is a fixed image stored as part of each library part. It does not reflect how the object has been parametrically modified. Line drawings without materials are possible of course and do show the modified object. I know of no way to include a render in the schedule - or any generic image file - that will be logically attached to the cell to move dynamically, and to dynamically reflect the changing appearance of the placed object.
I would like to set up all interior schedules in Archicad (furniture, sanitary, finishes, appliances, etc.). I'm trying to automate everything in Archicad as much as possible.
I have already set up a sanitary schedule and now i want to do furniture schedule, but i don't see any option to add an image of a furniture into the schedule. Is that possible to do in Archicad?
2022-09-12 12:51 PM
Hello all, I am looking to do the same thing as in the original post, the GDL image preview is just not an option for me, because you have to create a new library part each time you insert a custom image in the preview.
2022-12-17 06:20 AM
The video shows images inserted into a, very clean looking, schedule is possible. But it does not show what "(Add) Field" or "(Add) Criteria" allows this to be done?
Sunday
I figured it is possible to add images as annotation to the 3d preview of an object. The image can cover the original preview.
This is almost good, but:
- It doe not work with modules
- the image, like any annotation, tends to disappear if the object changes or new objects coming in to the project...
I wish I could create a property that is an image, not jut text...
Tuesday
It takes a bit of effort, especially if you have a lot of images, but here’s a method I’ve used in the past:
Additional tips:
Tuesday
Saving the images as objects is an interesting idea, however it is of very little use.
Say for example I want to schedule my tapware.
I want to place tap objects, give them id's so I can tag them in plans and elevations, I can create properties to add things like supplier, product name, WELS rating etc. The only thing missing for a nice tapware schedule is a nice image of the selected products. Unfortunately the object preview image is no good, unless I can find the model of the exact tap brand that I want to specify.
In other words, the tap object is just a generic plan/3d representation of the selected product. It is good enough for documentation, but I would need to be able to add an image of the exact selected product for clarity. Having a separate image object would provide no help in this regard.
An Image Property on the other hand would be great!
Right now I just add the images to the layout, but that way there is no connection between the image and the scheduled object, so if the schedule changes, I have to re-arrange the images...
Tuesday
Are these your own office objects or are they the default Graphisoft objects?
If they are in your own office library, then you could amend the 2D script.
Just thinking out loud here, as I have not tested this myself.
At the beginning of the 2D script add something like .. if GLOB_VIEW_TYPE = 9 (calculation), or maybe if GLOB_PREVIEW_MODE = 2 (listing) - (not sure which will be better), then if tap_type = XYZ then PICTURE2 XYZ.JPG, END, endif.
Then continue with the normal object script.
Obviously that is not the proper script (as I say just thinking out loud).
Then in the schedule display the 2D preview as well as the other object fields you want.
Hopefully the script will display the picture and then END the script if the object is listed in a schedule, but should display the normal object in the model.
