Teamwork message view capture doesn't capture floor cut plane
I don't know whether this is a known issue, an old unknown issue, or a new issue —I only noticed it today. The Teamwork message view capture is changing the viewed floor cut plane setting, perhaps restoring it to template default. AC 25 INT 4013, Mac OS Monterey. (If I click back to the saved view on the view map, the column base reappears.)
Video:
https://www.dropbox.com/s/6gc1b4buhm6f5ix/cut%20plane%20clip%201080.mp4?dl=0
1 Reply 1
Hi @Ignacio Azpiazu, I think Applying view button is transferring you to the project map view if so I think you try to do another step and open it from view map, a guess.
AC 29 INT 4006/WIN 11
