The Translator has disappeared
I tried to transfer object from 3dsmax in ArchiCAD. After that there was a failure In ArchiCAD. And already it has then ceased to be translated (that was not just) File from ArchiCAD in AutoCAD (DWG). That is does not emerge windows with the name Translator, with the subsequent pitiable result. Tool DXF-DWG Translation setup does not open. After closing the program ArchiCAD there is a window RUNTIME ERROR! Restoration of system, reinstallation of the program with cleaning the register by means of RegCleaner have not helped. Are You do not know how to correct a mistake?
0 Replies 0
