The file is locked by another application. Importing xref
Hello everybody,
I have a problem with importing Xref or dwg to archicad. It always says - The file is locked by another application.
The Dwg is used by a colleague when she closed it, I can import it. But that's not how it is supposed to work. We work on shared HDD, but if I import Xref into Autocad it normally works. I couldn't find any solution on Google. Does anyone know what to do, please?
2 Solutions
As discussed, it could be that someone else has the DWG open.
I have also found on a Windows system, just having a file selected in Widows Explorer with the 'preview' panel active, is enough for Archicad to think the file is in use.
Go to post
Eduardo Rolon
Also even if you close the file in Autocad the file can still read as locked until you quit Autocad.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Go to post
8 Replies 8
SeRohde
Hi Posednak,
You said
it would be helpfull to know how the files are shared.
Is it a windows share (smb version) or a mac share
Or is it a cloud service for example
Without knowing this I just can guess. Files might be locked because of:
  • An Antivirus is scanning for changes (make exclusions)
  • Another user once opened it, but the filehandle never closed (Windows check compmgmt.msc > shared folders. Carefull when closing sessions or open files with write access. This might corrupt the file)
  • Its a cloudbased sharing and the sync is on it (make sure when sync starts and is able to finish)
  • Several Archicad Users/Servers are on it..
Admin of BIM [Cloud] [SaaS] [Server] | AC 19-25 [Win&Mac Clients] | VM's
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you for the question and I am sorry about the issue!
If you cannot attach XREF while the DWG file is still being opened by your colleagues, this is a limitation with how Archicad read the AutoCAD file. When you open a DWG, a DWL (temporary drawing lock) file is created. Its function is explained here: https://www.cadforum.cz/cadforum_en/qaID.asp?tip=3186
I believe Autodesk applications have a different way to bypass this. Unfortunately, you (or your colleagues) need to close the file before you can start attaching the DWG as XREF.
Thank you very much for your understanding! Please let me know if you have any further question!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Best regards,
Minh
There is a setting in AutoCAD that enables xREF load with copy where AutoCAD essentially copies the xRefed file to a temporary folder in your hard drive, if this setting is not enabled the behaviour is exactly the same as that of Archicad
Regards
Scott
sumeyraozmen
I can not import the dwg file to archicad could you help me? I added my problemi as jpg
Eduardo Rolon
AC29 US/INT -> AC08
sumeyraozmen
Thank you very muchh
sumeyraozmen
Thank you very muchhh...
