2011-01-24 02:23 PM
2011-01-24 04:43 PM
2011-01-25 07:31 AM
Matthew wrote:Thank you Matthew for your quick reply. Do you think there might be some work around to be able to show that thickness (or a thickness defined by user)? Some scripting maybe? There are labels that can recognize skins' thickness for complex profiles (for example "Wall Label 12"), so I am thinking ... maybe there's a way to show that in schedules too.
Since the fills in a profile can be any shape, thickness is a special case condition (ie vertical, parallel sides).
2011-01-25 07:35 AM
2011-01-26 09:22 AM
Matthew wrote:Thank you Matthew for your suggestion. I will do some research on that.
It's been a while since I needed to do anything like this but perhaps it could be accomplished with a properties object.
