Eric, I used stuffit to unpack the file, and it seems to work fine. The program opens up, I can add information, templates are available, database cross-references between sheets, etc.
What is the possibility that the file got corrupted in the transfer process?
If so can I send it to you again? I'm running it on a G4 1ghz powerbook running OsX 10.3.9.
	AC 6, through 27
iMac 27' 3,1 GHz 6-Core Intel Core i5
500GB OS X12.7.3 Monterey
