Time management
I am wanting to streamline the time management process for projects and asking if there is something inherent in AC that will allow for tracking of time. Also was wondering what methods/software small firm owners use for time tracking on projects.
56 Replies 56
thx
Weird, but it won't run. I first get a POP3it error followed by:
"The temporary file "ArchiOffice User.AOD could not be created on the system disk. Use a difference name, make more room on the disk, or unlock it."
There is no such file in existence, there is plenty of room. Any ideas?
EDIT: the file IS there, but it still won't work.
Fritz T
No idea what that could mean.
I'll re-install the demo later today and see what happens, then post the result.
AC 6, through 27
iMac 27' 3,1 GHz 6-Core Intel Core i5
500GB OS X12.7.3 Monterey
I believe Archioffice offers a 60 day trial period for the latest release, but it looks like you have to buy the product and if you don't register the software it becomes locked after 60 days. Obviously this requires the up front purchase which is the downside.
Yeah, that's why I wanted to look at this demo again. Anyone have the windows version posted below?
Fritz T
Eric, I used stuffit to unpack the file, and it seems to work fine. The program opens up, I can add information, templates are available, database cross-references between sheets, etc.
What is the possibility that the file got corrupted in the transfer process?
If so can I send it to you again? I'm running it on a G4 1ghz powerbook running OsX 10.3.9.
AC 6, through 27
Hi Folks!
Here I am back again...
Another web based application wich I'm using for about 4 months is egroupware... You can test a hosted demo version at:
egroupware demo
Tell me what are your impressions.
Braza
