2005-05-04 05:32 AM
2005-05-05 10:54 AM
Scott wrote:historically, yes. but with AC9? i see no need at all to have a version of autocad around . . . of course, this does rely on your consultants being able to generate you a template file (most of which can't, but that ain't AC's problem
Wouldn't AC users like a copy of AutoCAD to help translate consultant files, details downloaded off the internet, legacy drawings, etc?
2005-05-05 11:31 AM
yeah, revit speaks DGN, too,i didnt know that in revit you can do your work in either format (dgn or revit format) i liked that..will check that out cuz could be great for ms users..thx
2005-05-06 08:57 AM
2005-05-06 07:22 PM
Djordje wrote:Maybe a year or two ahead, but I wouldn't call it 'light years' ahead! In any case, the fact that Revit is partially there is a step in the right direction for everyone. Shows Autodesk's commitment to IFC, which one can argue has been lacking in the past. With Autodesk on board wth IFC, it should help the industry at large to move closer to the goals of the IAI. I expect 'light years' to become milliseconds over the next year....
The implementation on the ArchiCAD side is light years ahead.
Djordje wrote:See my point about the gap rapidly closing? In many aspects, gap has been opened in the other direction....AC is now in the catch-up role.
granted that the numbers should be greater for ArchiCAD, as it is around for some 20 odd years.
2005-05-06 07:43 PM
2005-05-06 08:29 PM
2005-05-06 11:06 PM
Adalbert wrote:oh no....here we go!
Archicad is better because runs in a MAC
Revit does not run on a MAC
2005-05-06 11:40 PM
Ben wrote:Revit has Worksets. In simple terms, there is a central file, and users 'check in' and 'check out' portions of the model to work on. these Woksets are user defnable. I can check out "shell and core" while user "B" checks out "interior partitions". Both of us can work on these parts simulatneously. When I get done, I "Save to Central" which both pushes my changes up to the Central file, and pulls other changes that others have made to my local file. Revit also has element borrowing, where if I have Workset A, but need something from Workset B that you have open for editing, I can "borrow" that element from your workset, and then give it back to you. This is total teamwork.
Revit has no teamwork. How do you have multiple users working on a the same project? I have seen a humorous attempt at a teamwork like solution. The workset, look at the name, workSET it's not team working.
Ben wrote:How is it difficult? File>Export>DWG. Is there 'clean up'? Only if you need to clean up concurrent lines that can occur, because a wall and window header may be colinear. If you are going to Xref the DWG into another file, then there really is no clean-up necessary.
Stefan, thank you for going to the trouble of explaining about DWG conversion, but I know from first hand experience that is simply not that easy, it is a know fact, that it is difficult to get "Usable" DWGs out of Revit easily.
Ben wrote:SOM New York is designing the entire World Trade Center Freedom Tower in Revit, including Structural and MEP. Is that large enough at 1776 feet tall?
How does Revit handel large scale projects now? I know it has been a problem in the past, does Revit have a project under it's belt like the Eureka Towers project in Melbourne, Australia?
Ben wrote:No, it's not backwards compatible. Every Revit seat is on subscription. (if you choose to continue the subscription) So nearly everyone updates every release as soon as it comes out.
How is backwards compatibility? Can you save a Revit 8 project to 7 or 6.1? Lets face it, not every one upgrades straight away.
Ben wrote:Yes, they are as intelligent, and require no code to create. Now, I understand you don't have to know GDL to create AC content, but it sure helps, right? Every object is Revit is created in a graphical interface. There was a user here once that swore I couldn't make a parametric array in Revit. Well, you can. And much more...conditional formulas can be used as well as almost any mathmatical expression. A window family can add muntins as the size of the window increases. I can have one door family, with multiple panel options and multiple hardware options. Each of these configurations can be scheduled. I can have a half-glass panel with Lever hardware, and a solid panel door with panic hardware in the same family. I can make a change to the Hardware type in the schedule, and my model will reflect the change. Do they slow down the project? Not really. Each instance of the family in the model is just a representation of the loaded family. If I load a door and place one, or 100, the file size does not change significantly.
Does Revit have a GDL counter part? There are simply thousands of objects out there, ok Revit has objects, but are they as intelligent as GDL, if so, the objects that I have seen from Revit are much larger in size, therefore slowing down the whole project.
Ben wrote:Revit 8.0 (just released) has an API available. I'm sure we'll see some creative uses in the near future, including one from E-specs in which a change in a specification could actually change the model.
Finally, is Revit as open as ArchiCAD? Does it have an open API? I mean lets admit it if AutoCAD wasn't as open as it is, it would never have been as big or successful as it is today.
Ben wrote:I understand your reservation, but I believe its true. Don't get me wrong, it's not the entire program. Both have their strengths and weaknesses. I just think Revit has progressed so rapidly in a very short time, and that it's underlying parametric change engine foundation of 100% bi-directional associativity gives it an edge over ArchiCAD. I also believe that ArchiCAD's longer life is not necessarily an asset. It's built on older technology, and for 20 years of history, should be developed far beyond it's current limitations.
I just find it hard to belive, at the same time very ballsy, to say that ArchiCAD is now playing catch up with a program which is still in it's infancy, compered to ArchiCAD.
2005-05-07 12:53 AM
2005-05-07 01:19 AM
