Total area calculating
Hi! I have some apartments with mezzanine and I need to show the total area of the apartment in the reference floor (i.e. reference floor area + mezzanine area). I also need to show the total area and the net area.
Is it possible to "connect" two levels in the area calculating?
Create a Property, make it available for Zones, and set the value of the Property to the same values for all Zones you want to be calculated together. Those Zones do not have to be on the same Story. Then use this Property value in schedule criteria and fields.
Thank you very much, LaszloNagy!!!
Surely it's a complex process but it's the solution.
