Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
View Maps Management
Does anyone know how to create smart folders in the view map section like the ones created by ArchiCAD in the basic template?
Thank you in advance
These are called folder clones:
https://helpcenter.graphisoft.com/user-guide/88437/
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
1 REPLY 1
