WTF is wrong with export to dwg
I use to export archicad to acad without any problem, now in Ac11 i have a lot of problems. Simply, lines that must exist are somehow hidden behind nothing.
When i export to dwg, all lines are present but not visible, u can see that in pictures. Is there something that i must do or what ?
10 Replies 10
when export this is what i get
my export file and setings
Everything was working fine in AC 10
My AC is updated, and i have acad 2008
Its not woring no matter what i do !
Plz help, cos i need to export a lot of draings to DWG
this is to pdf export and it works fine
So who in GS broke export to dwg, WHO ?
So, next thing is, when i unlink section, everything is fine, so there is 100 % bug in translator !!!!
FIX THIS !
Sorry, Necko, no way to do it properly! That is why I am still on AC10! Everyone comes to this problem sooner or later:
http://archicad-talk.graphisoft.com/viewtopic.php?t=19626&highlight=
It is the uncompletely developed "wipeout" oblect which exists in Autocad and for some stupid reason AC decided to use!
A workaround: Save the dwg! Open it in AC, select all blank fills and delete them! Resave the dwg!
Laura Yanoviak
kliment -- did you ever try my suggestion to Publish to DWG with a MVO setting the Fill Background to "Transparent"? Tom Waltz suggested the same thing here and it seems to have worked.
I will try it 2 !
I did like to export to dwg with the wipeout.
When I translate to autocad 2005 from archicad 12, all the elements come out transparent. I have set the model view to show window background color. I have experimented with several translator methods for fills with no sucess. In 11, I could translate drawings to autocad in wich elements with window background color came out with "wipeout out" fill hiding elements underneath. Could somebody guide me to achieve this on 12?
So,you are the only one who liked it?!?
I kept experimenting with translation methods.
Currently some elements seem to come transparent on model space but fill with window background on paper space. (theres a visual clue) Ill keep experimenting...
