Wall length in the N-S direction
Hi guys,
I'm trying to make a schedule for the length of every type of wall spanning only in the N-S direction. More specifically, I'm interested in the length and height of each wall type. But only for the walls spanning along the N-S direction.
Just wondering what would be the quickest way to achieve this.
Thank you.
Erwin Edel
Depending on your version of archicad, make a custom property with an orientation flag and manually fill that out (select multiple walls and set things up). You can then schedule this custom property.
I don't think you can schedule a rotation to the project origin / axis.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
1 REPLY 1
Erwin Edel
www.leloup.nl
Windows 10 Pro
