Richard wrote:
according to the Installer, since AC22 was released, there were 29 bugs fixed for the Door & Window tool, but only ONE bug fixed (Coverings) for all of the other tools combined and support for Masterspec added for Keynotes.
Thanks for pointing that out Richard - the release notes haven't synced properly to the installation packages ā I'll get someone onto that. The current schedule for AC22 release onward should have shown the following:
Bracing
Fixes:
- ArchiCAD crashes if trying to Brace this building
- Able to choose Braces that shouldnt be available with EXT / INT walls
- Not enough Braces placed
- Brace Table shows the Brace Type sizes, should only show type
- Cant create a new brace type from the library part UI
- Brace name is displayed in the brace table
- Brace placement is exceeding maximum length
- Bracing units never change with height
- Bracing elements length not matching table brace length.
- AC20 - Bracing Presets
- Room in roof space
- Bracing types styles constraints wont stick
- unknown value 10
- ac21 drop down menu's missing from brace table object
- BRC-102 Can't delete a brace type
- Bracing tool showing incorrect BU's Achieved
- Bracing table disappear after update.
- Brace places on other side of wall
Improvements:
- Remove limit of 50 bracing elements in brace table
- Edit Brace from Brace set list
- Retain and restore calculation dialog settings between runs
- Allow to display achieved bracing on brace object
- The bracing engine should utilise more than one brace type
- The bracing engine shouldn't place braces through intersecting walls
- Show length to greater precision in brace object
- Bracing tool functionality - different lengths into the same bracing object settings
Cabinets
Fixes:
- Values confusion on different door leaf types
- Cabinets toe space is not merging when wall are turned off but set to a number higher than 0
- Module widths inconsistent
- A and B reversed for rectangular grid muntins
- Surface on draws / doors not rotating correctly.
Improvements:
- Corner cabinet
- Top panel for overhead and pantry cupboards
Coverings
Fixes:
- Can not apply a wall covering to a hot linked module
Doors+Windows
Fixed:
- Window opening lines 3D versus 2D elevations
- Window migrated to ac22 bug
- Can't add a door to a window
- Can't remove left door leaf in plan view
- The wall is not showing the line inside the wall of the pocket door
- Floor plan view doesn't match window set up
- Archicad Crashing when clicking adjust scroolbar to width to many times in cadimage window
- Door Frame not shown with Match Jamb option in door model settings
- Comparing cadimage window (door opening) in Archicad 22 and 21, Archicad 22
- Cadimage Pivot window display in window schedule
- Calculate Data is not working in the Doors or Windows Settings
- Door tool - Door Leaf surface settings are wrong in some door leaves
- MVO set to simple 2, doors smaller
- Custom Schedule Notes overwrite Structured Schedule Notes
- Doors & Windows Head Moulding, Embedded in the Wall not working properly
- Garage Door leaf not changing
- Pocket door is not showing correctly
- Flange not showing under Door Leaf (Door Tool)
- Exterior jamb moulding are missing at the hinge side of the door
- Pocket door UI mislabelled
- Cadimage ID tool bug
- windows with the slop corner showing a extension in DW schedule
- Surface orientation not matching in Cadimage Window and Door
- Corner post adds an extra grid down from the side when using the edge grid
- No dimension shown in D&W Cadimage schedule
- ARCHICAD freezes on opening project
- Schedule creating a gap between dimension and door image
- Missing frame under sidelights
- Window with no top panels tries to draw a top panel if the top panel height is greater than zero
Electrical
Fixes:
- Plate position and offset not set correctly in wiring symbol
- Adding components to circuits workflow
- Circuit wiring corrupts when changing colour
- Wiring doesn't update
- Plate should reorientate when dragged to a wall
- Click to place doesn't align to wall if default hotpot has changed
- Height of elements wrong after copy paste between stories
- Wiring doesnt update on edits
- Cant wire other items other than Lamps
- A placed components changes settings on just opening its settings
- Selection by component anchor fails
- [AC19] - created wall plate wrong - correct plate but wrong symbol
- Create Plate doesnt appear to work - doesnt hide original components
- Automatic placement doesn't work on complex profile walls.
- Electrical Switch-Plate
- When saving a preset it doesn't seem to lock the 'switch' button. (It doesn't grey it out)
- Delete a Wall Plate
Improvements:
- Prompt for Circuit Wiring object setting before placing
- Choose the order for wiring circuit
- UK Sockets with USB
- Intercom objects / wiring
- Simplify the labelling of electrical components
- Deleting a wall plate should leave its components selected
- Allow to turn 'wall snapping' on and off.
- No labels on any switches
- To have a quadruple switch and a double power plate
- Electrical Plates Improvements
- Adjust Width and height of the plates in AC 21
- Allow to wire to the symbol origin
- Wish: To be able to edit the text position for Electrical Symbols
- Wire electrical items in a specific order
- NZ AUS power points with neon lights REQUEST
- Add a center point to wall plates for associated dimensions in ele / section
- WISH: Option to have vertical or horizontal switchs, data outlets etc like the power outlets
- Wall plates improvements
- Wish to have a horizontal GFCI outlet
Keynotes:
Fixes:
- CVS import assumes UTF-8 encoding
- Linked Masterspec specifications are deleted if you update a single spec
- Cannot find label for a keynote in a schedule, cannot delete from Schedule
- Top key missing on 2nd row onwards in keynote schedule
- Keynotes Frames
- Dynamic hotspot disappeared
Improvements:
- Interpret "" as escaped double quote in CSV
Objective
Fixes:
Slab Edges Missing Interface images
Objective tool bug - rotation
Sites
Fixes:
- Recession plane angle is inconsistent
- Daylight angle fields editable when preset is applied
- Custom Daylight Angle doesn't work
Improvements:
- Add an option for the position of an arc boundary centre
- More options for site boundary arc annotation
Ralph Wessel BArch
Central Innovation
