Mats_Knutsson
Mentor
Why can't I use this expression in a GO?
I have an expression resulting in a string value valid or non_valid. I can't use it in my GO though. I can't even see it when adding properties to the GO rule. Why so?
Br,
Mats
AC 25 SWE Full
1 Solution
Some parameters (and expression-based Properties using them) are not available as Graphic Override criteria:
https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=70274&p=313988&hilit=graphic+override+para...
Go to post
4 Replies 4
runxel
It seems only Expressions that only use the "general parameters" can be evaluated in a GO.
Smells like a bug (by design) to me. At least it should be available when we set the "element type" in the GO to the right type...
Mats_Knutsson
Mentor
Thanks Lazlo!
I'd like to ask GS if it is my job to accidentally find these "not available" properties/parameters?
AC 25 SWE Full
Probably not, but if you do, it is appreciated.
