‎2007-07-06 02:22 AM
‎2007-07-06 02:27 AM
‎2007-07-06 02:33 PM
‎2007-07-06 04:44 PM
Stephen wrote:The Window Builder is pretty good -- far more flexible and powerful than any GS object -- and includes a pretty nifty Window Schedule object (although we usually have to explode it in order to get the output we need) -- like Stephen said, a bit tedious. We don't use the Door Builder -- this object does not work with the IS (so these doors are not included in our Door Schedule).
I recommend Door/Window Builder. It can be tedious to learn, but once you save some favorites, it's easy.
‎2007-07-06 05:05 PM
‎2007-07-08 01:48 AM
TomWaltz wrote:Thank you for your help.
As much as I complain about them, I'd recommend the GS doors & windows over an add-on unless there's something you really need to do that you cannot. Is there something you want to do that you cannot do with the GS doors?
‎2007-07-08 01:51 AM
‎2007-07-08 02:28 AM
BAS wrote:See the Object Depository > 08 Doors-Windows > Doors -- there are also some posts that discuss how this object was made.
I was also wondering how to do a cased opening and garage doors with the top corners angled.
‎2008-02-11 06:47 PM
Another thing I wanted to do was make an eyebrow window this size I was able to change the width but when I changed the height got another error message (second screen shot)Did anyone ever resolve the error in line 840? I am attempting a similar eyebrow window but run into the same wall as BAS. I need it to be 5' wide and 14.625" tall.
‎2009-03-18 03:47 PM
